heat for my cab
o
10-02-2005 11:46:30
i have a 1955 w/cab,i just got the motor back in and water hook ups for cab ,one on lower elbow and one on thermostat housing,i am not getting hot water up to my heater in cab,is there a better place to hook up the lines or a small 12v pump to help and just leave lines where they are at,if pump who sells them ? the outlet for hoses are just 3/8 pipe. thanks john
RDK
10-04-2005 20:12:59
 Re: heat for my cab in reply to o, 10-02-2005 11:46:30
Hook one line onto the right rear lower fitting on the engine block. The other line should go on the fitting just above the thermostat. This has worked perfect for us.
alberta dave
10-03-2005 06:29:49
I put a little square bus heater in my 1650D and had a terrible time getting circulation to the box. I found that I had it airlocked and eventually had to put in a couple of bleeder valves in order to get the whole system flowing. Loosen your clamps and make sure you have fluid all around. I taped into the hoses coming off the heat exchanger that is mounted on top of the Hydra-power unit. I think that a 1955 should be similar.
Josh H
10-02-2005 14:52:35
I'm not sure how to get hot water up there, but I have a 1655 with cab and I have never turned the heater on. Even in winter, spreading manure, that thing will get warm enough on its own.
