got it fixed, now to work it again...
Don-Wi
10-01-2005 17:59:59
I managed to take it all apart, clean it up, and replace the head gasket in my 1600 today. I took a few measurements, but they all checked out w/ what Ron @ Tesch Bros. had shown me in the book this morning. I cleaned off everything I could w/ a good scraper, then I used some Scotch Brite and solvent to get the rest off the block and the head. I torqued it to 20, 40, 80, then the final of 115, oil screw to 100. I put the rocker assembly and the valve cover back on, warmed the engine up and then took the cover and rockers back off, re-tourqued the bolts, and hopefully that does it. I think the problem was that they just weren't torqued right in the 1st place, they seemed to come loose way too easy to be brought to anything near 100 ft, lbs. (I'll take some of the blame from that one) Now I need to buy myself a feeler guage so I can properly set the clearance on the rockers, and when I do that i just might re-check the head bolts. On the plus side, the lift bolts are in the right spot again... Donovan from Wisconsin
