difference between oliver row crop and super
PLayman
09-28-2005 16:03:22
Can anyone tell me what the difference is between oliver row crop/ super/ and standard models and the hp for 77 and 88.
pllr
09-28-2005 18:53:02
 Re: difference between oliver row crop and super in reply to PLayman, 09-28-2005 16:03:22
Also, the supers have 2 square mounting pads with 4 threaded holes in them near the round cultivator holes on both sides....unless someone made a tub frame swap...
old
09-28-2005 17:33:33
Well to start off I'm no expert, but heres what I know. Row crop and super are the same but differant. Now if you say fleetline and super thats another story. The 77 and 88 both came out as fleetline and supers. Both of those where rowcrop tractors. The 77 fleetline was around 38HP the super was around 44HP the fleetline 88 was around 42HP and the super was around 55HP. The standard was differant still. They where a tractor with wide front end but it sat under and back a little and from what I have been told the 77 and 88 standard where both supers as far as HP. Others will let you know if I have all that correct or if I have left something out.
oliver28472
09-29-2005 05:33:33
 Re: difference between oliver row crop and super in reply to old, 09-28-2005 17:33:33
For a simple answer, let's just use the 88. You could have a row crop 88 that was designed for using a cultivator or other rc implements. This tractor would most likely have a narrow front end with both front tires within inches of each other. The front end could also be an adjustable wide front. This tractor could be a fleetline or a super. The difference here is when the tractor was built, with the supers being later. Supers have flat pads on the side of the cast iron frame the engine sits in and one on the front. These allow implements to be bolted on. The fleetlines don't have these pads but otherwise look similar to the supers. The row crops and standards were both made during these years. The standard has a non-adjustable cast iron wide front axle and usually smaller diameter rear tires. Some also call this a wheatland tractor. You could have a Super 88 Row Crop or a Super 88 Standard. You could have a Fleetline 88 Row Crop (usually just called 88 Row Crop) or a 88 Standard. All this applies to the 77 as well. Another difference was that the fleetlines had louvered steel panels covering the engine (called side curtains). Supers did not.
