Oliver 1265 Fluid Filter Location.
Ron Ellis
09-27-2005 17:26:16
I recently purchased an Oliver 1265. I was wanting to change the fluids but I cannot locate the location for the fluid filter also is there only one drain plug and feel plug for the hydrolic fluid. I purchased a spin on type and an element type. I think its the element I cannot find the screw on type. Thank s Ron
JD in da UP
10-02-2005 17:28:58
 Re: Oliver 1265 Fluid Filter Location. in reply to Ron Ellis, 09-27-2005 17:26:16
I recently purchased an Oliver 1255 and have had for several years a white 2-60. Both have a horizontal canister on the right side of the tractor, down low. That will have a cover that faces the back that has 2 bolts holding it in place. Inside will be a magnet and a fine washable filter made of stanless steel. There should be 2 plugs under the transmisson and rear end. Filler is a small dipstick up towards the front of the tranny cover.
