Oliver 70 oil filter
JD730D
09-26-2005 13:58:45
Could someone please tell me what oil filter (brand & part #) the Oliver 70 takes? Mine is a 1941, cartridge (not spin on), and I can"t find a oil filter for this model, can"t be that big of a deal. What is in it, is a Napa 1126, but napa tells me # does not exist, replaced with #1105, which is a spin on, Help!! Thank you!
jac in pa
10-08-2005 01:32:33
 Re: Oliver 70 oil filter in reply to JD730D, 09-26-2005 13:58:45
im not shure that your engine has the right filter on it,i have a 1940 oliver 70 and it takes a spin on filter ,have worked on a lot of the older olivers and have yet to see one with a canister type filter, but i can tell you this the 70 has a continetal engine in it, maybe if you find a shop that deals with that brand they may be able to help someone may have replace the engine at one time with one out of a piece of other equipment or power unit worse case just change it over to fit a spin on filter its easy and will save alot of hassel
