Oliver 1250 engine removal
R. Sherwood
09-26-2005 13:00:02
Have a 1250 Oliver W/Fiat gas and need to pull the engine. Only can get it about 1/4 inch away from bell housing and will not go any further. Have everything lose that I can see. Can someone tell me what is stopping it from coming all the way off?
mayeux_air
09-27-2005 05:25:53
 Re: Oliver 1250 engine removal in reply to R. Sherwood, 09-26-2005 13:00:02
did you remove the shaft in front of the
engine that goes to the pump?? also the frame
bolts go to the oil pan...jeff m
R. Sherwood
09-27-2005 06:06:15
 Re: Oliver 1250 engine removal in reply to mayeux_air, 09-27-2005 05:25:53
Thanks, Yes I have everything off in front of the engine and the oil pan is off, like I said,it does move ahead about 1/4" or a little more. Thanks, Jeff
mayeux_air
09-27-2005 07:35:41
 Re: Oliver 1250 engine removal in reply to R. Sherwood, 09-27-2005 06:06:15
sounds like the clutch plate is froze
on the shaft!!! keep rocking the engine,,
