880 three point query
Tx Oliver Dude
09-23-2005 13:08:11
Hey folks,
Just bought an 880 and am looking for a three point for it. Anyone have a spare, or have a friend with one, or a friend of a friend ?? Also, what models used the same lift ?? Give me holler, thanks
Tx Oliver Dude
09-24-2005 17:34:18
 Re: 880 three point query in reply to Tx Oliver Dude, 09-23-2005 13:08:11
Thanks fellas for the info, I'll be looking through the local salvage yards, but down here there's mostly that other green.. I'll probably post a want ad soon, but I would rather deal with the good ole boys rather than a parts dealer (I like to cut out the middle man). Thanks again, Dude
770
09-24-2005 17:12:36
Oliver made the "hydra hitch" which is a positive type three point and the "power traction" hitch which is if you will the "heavier" version. They will both fit the 770 and 880 I believe. The power traction hitch"s lower member bolts up to the botom of the transmission housing forcing more of the impliments weight toward the whole tractor. Try calling some of the salvage yards. They"re quite a few in Ohio, or look in the back of the Oliver heritage or HPOCA magazine classifides. They are not cheap, but my power traction hitch does work pretty slick on the snowblower, disc....etc...
Oliver Power
09-24-2005 15:38:51
There are two different factory three points which will fit that tractor. One three point will fit the 77 , 88 , super 77 , super 88 , 770 , and 880. The other one (power traction 3-point) will fit the 770 and 880 only. The power traction hitch bolts to a mounting block under the tractor-just ahead of bull gears. Look under the tractor. You will see where the power traction 3-point bolts on.
