voltage regulater
tim coltman
09-19-2005 11:34:45
hi i need to put a new 6 volt vr on my 88 does it have to be something special or can i just get one from my local auto store and put it on? tim
John T
09-19-2005 19:52:50
 Re: voltage regulater in reply to tim coltman, 09-19-2005 11:34:45
Tim, one consideration other then the obvious CORECT VOLTAGE is to insure its suitable for your tractor ground, i.e, Positive or Negative. They make 3 terminal VR's (BAT ARM FLD) and 4 terminal (BAT ARM FLD LOAD) but I can tell you how to wire either to work, but suggest you get one the same as the old to simplify things. They also make Class A like most tractors use (probably yours) but some Fords (I believe) use a Class B type which wont work on the more typical Class A systems which you probaby have.
John T Nordhoff in Indiana, retired electrical engineer
