880 gas
Sockfarmer
09-19-2005 08:22:31
I have an 880 gas we use on the farm and there is a pull coming up an i'd like to take it over. its a strong tractor but its factory stock. Is there any quick tricks that can be done for an extra few ponies. Timing, carb, dist, etc?
ejr-IA.
09-19-2005 11:01:40
 Re: 880 gas in reply to Sockfarmer, 09-19-2005 08:22:31
Lighten the govenor weights and stiffen the spring,. advance the timeing.
weaver
09-19-2005 09:20:15
Just keep it stock and pull for fun. Just tune it up like kwf said. I pull a stock 770 periodically but only for fun. I do win part of the pulls against some modified tractors. Horsepower isn't everything in a pull, just part of the equation. If you stay close to stock you can still go home and use the tractor tomorrow without fixing it. I was just at an Oliver show over the weekend and about 90 percent of the tractors were modified for pulling and no one pulled one stock. Not to be hypocritical but a mostly stock IH out pulled them in the classes it was in. When they spun out it kept lugging just enough to pass them up. It also went back home to the farm to work the next day.
sockfarmer
09-19-2005 13:21:48
 Re: 880 gas in reply to weaver, 09-19-2005 09:20:15
I've plowed w/ it, 4 14s in 2nd gear and it will pull till the cows come home. At night there is a steady flame and the front end will float just a little when she pulls down. It weighs 7500# the way it sits. 15.5 38s full of water and a set of plate weights in the front. The only problem is that it has the power traction hitch, but if IH fast-hitches are legal, so should the power traction. i have a friend who pulls a JD A and boy would I love to shut his mouth.
Weaver
09-20-2005 08:51:23
 Re: 880 gas in reply to sockfarmer, 09-19-2005 13:21:48
I pull with a power traction hitch and have never had anyone say anything. As long as you keep it at a set position and don't move it I don't think you will have a problem. It's an easy way to get the perfect hitch measurement.
kwf
09-19-2005 09:58:20
Yes Weaver is right, there is alot more too it than horsepower. One of two things will happen when you pull, spin out or choke. Weight set up, tire pressure and hitting the track at the right place are the biggest factors.
kwf
09-19-2005 09:02:16
You Probably do not need any help. I pull a stock 880 gas with 16.9 x 38 rear tires in 2nd gear in 6000-7000 ob classes and win regularly. If yours has a power booster you could pull up to 10000 lbs. Just a few small things, would be good clean high test gas, new plugs and an electronic ignition would help a little. make sure timming is set to factory specs.
