What will all bolt into a 88 ?
Hank L
09-18-2005 19:41:54
Just wondering if a 310 will bolt right into a 88? Any others?
tom upton
09-19-2005 14:24:51
 Re: What will all bolt into a 88 ? in reply to Hank L, 09-18-2005 19:41:54
Dont know this from my own experience , but I was at a pull on sunday and a fellow had a 310 in a 880. He said the only trouble he had was he had to use the 880 bellhousing and clutch as the one on the 310 was too big to fit between the frame. Why do you want to put a different motor in your 88?
ejr-IA.
09-18-2005 20:22:38
The block will bolt right in the 88 frame short water pump shorten trans shaft raise radiator a little.It will go.
880 diesel puller
09-23-2005 10:29:00
 Re: What will all bolt into a 88 ? in reply to ejr-IA., 09-18-2005 20:22:38
I have a 310 diesel in my 880. trans shaft does not need modified or radiator does not need raised. it will set right in. rear plate back needs to be from the 880 though.
