morepower
ollie66
09-18-2005 16:01:28
what can be done to a 66 oliver to increase horsepower without stroking it. Thanks
ollie66
09-20-2005 05:24:31
 Re: morepower in reply to ollie66, 09-18-2005 16:01:28
Thank-you for your help. Some good ideas to try. Thanks again
kwf
09-19-2005 09:08:34
A friend and I built a 66 to pull with following modifications. 3 5/8" sleeve kit that will go in without boring, head work-took intake valve put in exhaust side and put 360 Crysler valves in intake side, electronic ignition, and a good Carb built by the right person. He has not lost this year in 3500 and 4000 lb classes with 13.6 x 38 rear tires.
770
09-18-2005 17:11:26
What about the 3-3/4 bore kit? headwork? manifolds? carb?.....
ollie66
09-19-2005 07:08:26
 Re: morepower in reply to 770, 09-18-2005 17:11:26
Will the 3 3/4 sleeves fit without boring the block? Also is the manifold from a 660 better than the 66 one? Thanks again
A.P.
09-19-2005 09:42:01
 Re: morepower in reply to ollie66, 09-19-2005 07:08:26
The 3 3/4" bore psiton and sleeve set for the Super 55,550, 66, Super 66 and 660 will install without boring the block. I am not sure the 660 manifold is better buit would not hesitate using it along with the better flowing 660 carb. Concentrate head and manifold porting work for quality air flow on the intake and exhaust side.
770
09-19-2005 14:32:03
 Re: morepower in reply to A.P., 09-19-2005 09:42:01
Head and manifold porting is CHEAP power. Done right, you will see at least a 5 horse increase on a 66 motor. Not hard to do, just don"t OVERdo.
