clutch issue continues
Jeg
09-18-2005 07:42:03
I have posteed an earlier message about the cluth on my 1800 not disengagin ( see earlier post). Well I put a longer spacer between the pressure plate and flywheel ( still wonder what the correct length is) and watched the movement of the pressure plate. When the pedal is depressed the plate will move away from the friction disc about 1/8" ( a visible gap) however the clutch still will not disengage the motor from the transmission. Anyone hav any idea? trying to avoid taking back out the motor I just pu in.
Any insight is deeply aprreciated
J. Schwiebert
09-18-2005 08:30:08
 Re: clutch issue continues in reply to Jeg , 09-18-2005 07:42:03
Which way did you install the drive disk? The wide part of the hub goes to the back? Did you change the pilot bearing?
old
09-18-2005 08:11:06
Did you put the clutch disc. in backwards?? If you did theres where your problem is. Guess how I know, been there done that once and will never do it again because its a pain when you do because you have to pull things again.
