80 Oliver
vf4x
09-15-2005 19:30:42
My winter project will be the rebuild of an Oliver model 80 4 cylinder engine. Can anyone recommend a parts source?
RAB
09-16-2005 09:54:13
 Re: 80 Oliver in reply to vf4x, 09-15-2005 19:30:42
Apart from a head gasket, what do you need?
I have been pointed towards Olson(?) Gaskets, but not yet used them. I have one ready to rebuild but don"t expect to do more than remove shims for the bearing clearances, mill the Oil pump to clearance spec. as necessary and fit new governor shaft bearings. The rest is remarkably good - tough old engines!
Other gaskets are all easily made up using appropriate gasket material and a ball-pein hammer.
Regards, RAB
vf4x
09-16-2005 11:38:11
 Re: 80 Oliver in reply to RAB, 09-16-2005 09:54:13
I plan on a major out of frame rebuild. I have'nt started as of this time consequently I do not know what I will need. I probably won't need any hard parts as I have a total of 3 engines. Thanks for the reply.
