oliver 770 gas -- engine stall
JimMidwest
09-14-2005 23:10:59
I've recently encountered an engine stall problem. As I approach working temperature range the engine stalls. Can immeidately restart but won't stay running. I can repeat the same routine after about 10-15 minutes. I've replaced coil and plug wires. Any suggestions would be appreciated.
RAB
09-15-2005 10:26:41
 Re: oliver 770 gas -- engine stall in reply to JimMidwest, 09-14-2005 23:10:59
Replaced coil and plug wires when - before or since the problem?
Do yourself a favour and check whether there is a good spark or even no spark when it stops. That way you will know whether it is ignition or fuel related.
Will it start/run with choke when problem occurs? Regards, RAB
