overhaulin' 1650 diesel
Rich Iowa
09-14-2005 18:26:52
I don"t need to yet, but someday I might like to get the engine overhauled. How much/ how hard is it to do on these tractors? I don"t have any place to do this myself, like a heated shop with all the tools :). Where have some of you taken your toys to be redone, local garage, regular diesel shop? The last engine I overhauled was a 5hp Briggs in HS couple years back. Rich
alberta dave
09-15-2005 09:04:27
 Re: overhaulin' 1650 diesel in reply to Rich Iowa, 09-14-2005 18:26:52
We have an Ag College near by with a full Ag Mechcaniacal school. They will take farm equipment in for work to train their students. I checked on getting my 1650D rebuilt there last year and I was told that it normally costs about $5000-$6000 to redress one of the Wakesha engines. They also told me that they normally require some machine work which adds significantly to the cost. I think you can buy a redress kit yourself for under $2000 but by the time you get the head redone, new water and oil pumps I doubt that you can do DIY for less than $3000.
MH
09-15-2005 05:43:35
I've kinda been thinkin the same thing. My old 1650 is getting a little long in the tooth, and might need a rebuild here in the next few years. Never have gotten too deep into an engine before, but with the help of guys like Don I figure I might learn something along the way.
Don-Wi
09-14-2005 20:34:20
I did my 1600 gasser for about $3000. $1500 in parts, 1500 in labor for an engine shop to do it. I asked them about doing the 1755 deisle, they said they really don't build deisels, but they'll grind the crank, hot tank it, press in the new cam bearing and replace the sleeves if I want. I'd imagine they'd do the rest, but it'd cost a little bit more. Pulling the enigine isn't too hard as long as you have enough capacity to lift it. I'm sure you've also read to pull the PTO out of the back. on the 1600, it was a snap to pull the shaft. Loosen the cover, then there are 3 bolts that hold it in. Take them out and pull it out. The splines may get hung up on the hyd. pump, but you just have to turn it a little and pull again. I'd call around to a few shops for an estimate on rebuilding if you don't have the facilities to do it yourself.
Donovan from Wisconsin
