Super 88 Diesel
SuperBill
09-14-2005 09:21:50
Just finished a rebuild on a Super 88 Diesel. New sleaves and Pistons, head was reworked. Sent the Injection Pump and Injectors out. Now it has a miss when cold. It is more then one cylinder and it gets worse the higher the RPMS. Once warmed up it really can pull.
Any ideas.
J. Schwiebert
09-14-2005 12:57:52
 Re: Super 88 Diesel in reply to SuperBill, 09-14-2005 09:21:50
So are you asking where the miss is comming from or telling us the performance is good? Since you said it missed and gets worse with an increase in RPM, Double check your timing. Also take the manifold off and see which cylinders miss. It sounds like you may be one set of hole late in time. Chrome rings, keep at least a 45-50 horse power load on it so those rings seat in quickly
