88 olivers
davel
09-25-1999 11:36:57
is there anything that can be done about the whine in the transmission
Cory Z.
09-28-1999 18:14:38
 Re: 88 olivers in reply to davel, 09-25-1999 11:36:57
The whine in the transmission, most apparent in road gear, is simply the result of the sloppiness inherent in a spur gear transmission. As the teeth mesh together, there exists a certain clearance that causes the teeth to strike one another and behave much like a tuning fork does when you strike it. The harder you strike it, the louder it whines. Oliver was not the only manufacturer to have this problem. A number of customers complained about these noisy transmissions in the Fleetlines and Supers. We have to live with them. But Oliver introduced a helical gear transmission in the 880 and this reduced the whine significantly. A thicker oil will help somewhat also, but otherwise, as others can attest, you must simply live with it.
highboyford
09-25-1999 21:05:36
Gear lube.
Dick L in NW Ohio
09-25-1999 14:47:47
Buy ear plugs
