Unknown Oliver Plow
djt
09-12-2005 17:56:27
third party image
Does anyone recognize what model plow this is? I was wondering if it is worh buying.
Thanks
IanC
09-12-2005 19:29:05
 Re: Unknown Oliver Plow in reply to djt, 09-12-2005 17:56:27
If the land wheel track is cut by the third bottom it'a a 4240, if the land wheel track is outside the cutting path of the third bottom it's a 4340.
djt
09-12-2005 19:41:23
 Re: Unknown Oliver Plow in reply to IanC, 09-12-2005 19:29:05
third party image
Does this pic help any?
IanC
09-13-2005 17:55:05
 Re: Unknown Oliver Plow in reply to djt, 09-12-2005 19:41:23
Definatley a 4340. Looking at the frame holes it looks like it is set up as 16" cut. You can unbolt the frames and set them up as 12,14,or 16" cut per bottom. You should be able to buy reproduction manuals from the Floyd County Museum in Charles City.
djt
09-13-2005 20:26:51
 Re: Unknown Oliver Plow in reply to IanC, 09-13-2005 17:55:05
By the way, what years were the 4340's made? I am looking for something to pull behind a non super fleetline. Will a 77 handle this in reasonable soil?
djt
09-13-2005 19:51:48
Ian, can you remove one of the bottoms on these? My case plow has that ability. I dont have enough power to pull a 3 bottom... yet!!
IanC
09-15-2005 18:15:28
 Re: Unknown Oliver Plow in reply to djt, 09-13-2005 19:51:48
Yes you can drop it down to two. If you get a copy of the set up and operators manual from the Floyd County Museum it will tell you how.
Josh H
09-13-2005 17:31:34
Its a 4340. Wearable parts are easy to get, at least in s.e. PA. I have one, it does a nice job, but takes a good bit of power to pull. I pull it with an Oliver 1655.
ShepFL
09-12-2005 18:15:58
To me it looks likes a 4340. I like mine but mine needs some work. I paid $100 for mine.
djt
09-13-2005 05:28:54
 Re: Unknown Oliver Plow in reply to ShepFL, 09-12-2005 18:15:58
Shep, Can you still get shares and other wearable parts for these plows?
