The gear was not going quietly
Craig A Tull
09-10-2005 15:16:51
Well I went down and removed the steering box and pedestal (narrow) It did not go as planed, it was going just as Wrenchbender had said, but the gear was not going quietly, the engine radiator etc. was already gone and I found I needed to remove the grill to get the oval cover off of the box, no problem and it gave me total access the box, but the gear was not going quietly, it took allot more torque than I was comfortable with, so I let it sit for a while whilst I pillaged this and that here and there, pulling it a little tighter now and then and trying to let my intensions be known with my 10lb brass hammer, but the gear was not going quietly, first the snap ring deformed pulled out of it�s groove, beat it back in shape with a ball peen hammer and re-installed it upside down, that worked fine until the welds holding the washer to the bolt let loose.
I then decided to try pulling it as one piece and that was no problem until the �hand� that was operating the forklift decided to give me a little help grabbed the front wheels and gave them a hefty twist just as I was checking the clearance (read face about where crankshaft pulley used to be) I saw him crab the wheels but it was too late to react, I got a really good blast of hydraulic fluid right in the eyes. Well anyway if anyone was curios the complete pedestal, steering box and two flat tires weigh about 340 lbs.
The business for �insurance� reasons will not let me bring in a torch. A new snap ring, re-weld the washer and a little heat and time and I think the story will change.
Thanks Wrenchbender you were right on target for the info I was looking for.
Craig
