77 input shaft help
Can't even use
09-09-2005 12:42:32
Just got a 77 with a shot clutch. Went to South Bend Clutch and got a new one and had them check out the pressure plate and fly wheel. Also got an new throw out bearing. The sleeve for the pto in the flywheel is bad so we got a new one of those and the coupler to the transmission input shaft was bad so we got one of those on the way too. However, the input shaft is bad so how do you get it out. The tractor has hydraulics but no belt pulley. I assume you have to take the top cover off and get at some snap rings but any advice would be great, thanks in advance.
Jerry B
09-09-2005 14:07:55
 Re: 77 input shaft help in reply to Can't even use my name, 09-09-2005 12:42:32
Pull the pto assembley out of the back of the tractor.
Remove front input shaft housing from trans case.
Put trans in neutral and remove shifter lever being careful not to drop the 2 springs and 2 plungers into trans.
Remove trans top cover.
Have lock ring pliers handy as you have a few lock rings to deal with.
