COCKSHUTT 570 POWER STEERING PUMP
MMGUY
09-09-2005 08:04:17
Does anyone know of a source for a power steering pump for my 570 diesel. It is an Eaton pump. Part # in my parts book is MAO-570. THANKS.
P. Heisey-Harleysville,PA
09-09-2005 16:43:34
 Re: COCKSHUTT 570 POWER STEERING PUMP in reply to MMGUY, 09-09-2005 08:04:17
MMGUY,
Early Case tractors used an Eaton P.S. Pump. Check out larger heavy duty Ford, Dodge and International Trucks in the 1957 thru 1965 range.
I have O-Rings, shaft seals, shaft bearings, and the can filters on stock.
Phil Heisey, 215-256-8651 FAX 215-256-1203
J. Schwiebert
09-09-2005 17:35:50
 Re: COCKSHUTT 570 POWER STEERING PUMP in reply to P. Heisey-Harleysville,PA, 09-09-2005 16:43:34
Several years ago I worked on a 570 that is in the neighborhood. He had left the unit go to long and it had ruined the pump. I found one off I think it was a 30 series Case. I did have to change how the return line entered the reservoir if I remember correctly. Also older Char-Lynn add on units used the Eaton pump. You might also be able to substitute another pump from a different manufacture.
