Oliver 70 Governor
Tony's Tractors
09-08-2005 13:15:09
I have a 1937 Oliver Hart Parr 70 that the governor is not working on and need some help. As soon as you start to open the throttle up it just rips the carb wide open and sounds like it is going to blow up. Now, I have heard of the flyball bearings going out and needing to be replaced to fix this...how do you know if the flyball bearing is bad? I opened the governor and the bearings and weights all look good. I need some help. Anything is appreciated!!!
oliver power
09-09-2005 17:41:50
 Re: Oliver 70 Governor in reply to Tony's Tractors, 09-08-2005 13:15:09
I had an oliver 70 tractor that did the same exact thing as you describe. It was the flyball bearing which caused the problem. I replaced the fly ball bearing. Governor worked good , until next time. Of course , I would always get flyball bearings from used tractors. Some lasted longer than others. I'll bet I had replaced that bearing about 5 or 6 times. Had that tractor about 8 years.
