1855 PTO slipping-air test?
Bruce in KS
09-07-2005 21:16:20
PTO slipping with mower when lowered onto grass.
Shaft surged in speed a few times after entering grass (slowed down, then sped up real fast). Motor never bogged down. Inspection of linkage appears okay. When the PTO lever is moved to engage I hear a click within the first inch or so and then the lever continues to move the linkage the rest of the way. Haven't gotten my manuals yet, but I removed the two allen plugs to the right of the PTO to check what I beleive to be the tranny fluid level. Nothing came out of the top one, but the one 4-5 inches lower, had oil waiting to run out.
Can anyone elaborate on how to do the air test I have heard about? I can see the two lines. Also, can I do the test with my 150psi air compressor? I read the PTO runs 210-225 psi, do I need to make that for the test?
Thank You in advance!
Bruce in KS
09-08-2005 20:34:15
 check, doublecheck, triplecheck! in reply to Bruce in KS, 09-07-2005 21:16:20
For the 2nd time this week I have encountered what I thought to be considerable problems only to have them turn out to be minor.
Mower hooked to PTO
I decided to inspect the PTO linkage/lever again today (3rd time). Turns out that I can hear a click within the first inch of movement, then the lever moves another 3 or so inches , then you can force the lever an additional inch with 20+ lbs of force. Well, the PTO shaft will start turning after the 1st inch of lever movement, thought that was it. I never could figure out the surges of shaft speed until more experimentation tonight. I got my surges by holding the lever all the way, but after I got a surge I would let go of the lever and it would move back that one important inch. SHaft would remain spinning fast for a 10-15 seconds then eventually go back to the initial spin which if lowered onto grass slows down shaft considerably. Well, I decided to imprint the lever into my hand by pressing the lever that final inch with 20+lbs of force. PTO shaft speed surges then stays, stays, stays and voila! stays constant even in grass. PTO is working fine. I tried to adjust the linkage by shortening it, but if I do it any, I won't be able to turn the PTO off.
I guess, I will think of something, or get some thick leather gloves.
Had the new pressure gauge and fittings out to test the line pressure tonight, but the Hydraulic Fitting guy disregarded the flare nut diameter and gave my wife the 1/2inch instead of the 7/16ths I requested. Oh, well, I ought to thank him for distracting me and allowing me to find the real problem. Sort of feel like an idiot for posting my 2nd linkage problem of the week, but how many times do I have to check stuff? Alot I guess!
J. Schwiebert
09-08-2005 10:55:07
 Re: 1855 PTO slipping-air test? in reply to Bruce in KS, 09-07-2005 21:16:20
Have you checked the pressure to the PTO control valve? It is easy and then you know if it right or not.
