550 oliver problem
S. Thomas
09-07-2005 19:30:38
I have a 550 oliver that acts like it is running out of gas, it may run between 20 min. to 1hr at low rpms or high rpms then it starts to spit and sputter and act like it is dying. You can pull out the choke and work it back and forth, or some time throw the throttle wide open and it will come to life.Then in 2 to 5 min. it starts all over again and again. I thought of vaper lock so I put a heat shield on and rerouted the gas line, the gas line is 1/4 tubing, gas tank clean and so is the lines. HAS ANYONE GOT ANY IDEAS!!! THANKS FOR THE HELP!!!
jake3x
09-08-2005 08:39:28
 Re: 550 oliver problem in reply to S. Thomas, 09-07-2005 19:30:38
Check the gas cap and make sure the vent is clear, a plugged vent will cause a vacume stopping fuel flow.
MikeWisc
09-08-2005 05:48:00
I agree with the coil diagnosis. I had similar problems on both my 550 and 1550. It was the coil both times.
Barry-KC
09-07-2005 21:14:04
On my 550, a tired coil caused similar problems.
Good Luck
old
09-07-2005 20:51:56
My guess would be junk in the carb.
