Co-Op E3 help please
Edward1
09-07-2005 07:02:39
I am considering purchasing a Co-Op E3 with a loader. Do these tractors have a 3pt as well? Will the loader be capable of lifting a 12-1400 pound round bale on a weekly basis? I have always owned red and green tractors, but orange will be fine if it will fit my needs without risking damage to the tractor. I"d rather be over tractored than tear up a perfectly good piece of vintage equipment. Thanks for any help.
P. heisey-Harleysville,PA
09-07-2005 16:20:54
 Re: Co-Op E3 help please in reply to Edward1, 09-07-2005 07:02:39
Edward1,
Paul and krm are providing good info. and advise. Look for a heavier, newer tractor with improved hydraulics for your big bale handling tasks.
Phil Heisey 215-256-8651 FAX 215-256-1203
Paul Frey
09-07-2005 08:21:17
That E-3/FEL combo probably does not weigh over 4500 pounds, unless ballasted with fluid in the tires and weights. Then it would only weigh in shy of 6000 pounds. I'd want a hole lot more iron to move such big bales. Don't have hydraulics or hitch on mine, so I can't comment on them.
krm
09-07-2005 07:13:35
I would be very surprised if a e-3 Co-op would handle a bale of that size.It would have to be a standard front axle and have a external hyd pump.The 3pt was an option on these tractors, but are hard to come by and are weak.
krm
09-07-2005 07:13:23
