Toolbar for 880 Oliver?
Jimmy in Minnes
09-06-2005 09:50:13
I have an 880 Oliver, which has been the most reliable tractor we have ever had.
There are two round holes in the frame, which I assume are for a toolbar. How common are these and were they used for a planter and cultivator? On the 880, were they a four row unit? How common are they to find? Does anyone have a picture of one or one to sell?
Thanks,
Jimmy
J. Schwiebert
09-06-2005 14:49:19
 Re: Toolbar for 880 Oliver? in reply to Jimmy in Minnesota, 09-06-2005 09:50:13
If your 880 has a Power Booster, the rear pipe will not slide through as the Power Booster blocks that hole on each side.
Boco
09-06-2005 18:06:24
 Re: Toolbar for 880 Oliver? in reply to J. Schwiebert, 09-06-2005 14:49:19
I grow up with a 37HP 70with the pipeframe cultivator and another on a 42 or 44 don't remember. Then had two 4row cultivators on Super 88's that mounted on the pads on the frame. Don't remember #'s of the 4row ones, it was somewher back in thr 60's. I'm in adifferent occupation but brother still farms, but now cultivators here are about like bottom plows. Boco
B A Star
09-06-2005 11:46:14
third party image
Here is a scan of a photo showing the "QD" or pipe cultivator mounted on a 88 tractor. Scan is from the 88 tractor literature. The QD cultivator was available in 4 row. The holes in the frame of your 880 are to accomidate the QD cultivator. The company did that so that the farmer that bought a new tractor could use his old model cultivator. The cultivator that was current when the 880 was in production was the 600 series, it mounted to the front and side pads on the tractor frame. It was avaiable in 2, 4, 6 or 8 row. By the way those that Have asked why the motor in the Oliver tractor run "uphill", here is the reason why, so that the front pipe would go under the engine. That design continued for a long time.
