310 Waukesha injector pulling tool
MikeOwi
09-01-2005 05:31:25
Any where to get one of these reasonable? We still use 3 1855's with Waukesha's and I would like to have this tool around.
mak
09-05-2005 07:46:38
 Re: 310 Waukesha injector pulling tool in reply to MikeOwi, 09-01-2005 05:31:25
Our local NAPA got us one made by OTC. It cam with a little slide hammer and the tool that grabs the nozzle for around $90 bucks.
J. Schwiebert
09-01-2005 11:29:25
The tool was made by OTC. It has a John Deere tool number. I can look it up if need be I can also check if it is still available. John Deere starting using the Roosa Master nozzles (injectors) about 6 month before the 1750 engine was introduced. Questions?
MikeOwi
09-01-2005 15:50:00
 Re: 310 Waukesha injector pulling tool in reply to J. Schwiebert, 09-01-2005 11:29:25
Are these hard to find? I was kind of hoping someone would have one available to be purchased.
joe/pa
09-01-2005 07:07:45
I use a long flat screw driver and pair of pliers, tap and pry gently. They usually pop right out on my 1755
L Klingler
09-01-2005 06:15:17
We made our own, I am sure any diesel shop should be able to get you one. Larry.
Luke S
09-01-2005 06:22:10
 Re: 310 Waukesha injector pulling tool in reply to L Klingler, 09-01-2005 06:15:17
I used a pair of pliers and a small hammer and tapped the pliers and they poped right out on my 1955.
