Oh mr. Schwiebert - found the problem
jeg
08-30-2005 18:51:00
I am the one with the 1800 gas - pto issue. Well, I kept looking at how the driveshaft does not line up so I took the liberty to remove the pto unit. Lo and behold it is very obvious why the shaft came out hard initially and goes in hard - the inner cast piece (called the inner bearing support) is cracked BAD. It looks like someone has been in there before as indicated by the RTO gasket. Their is actually a piece broke out of the casting (looked on the rear end for it but it is not in there - maybe taken out in the previous disassembly)
That all being said, are my options:
1. reassemble the current unit and leave the driveshaft out ( or does that shaft also run something else)
2. try and find a replacement. This is what I would like to do but I don"t know who may have one in a boneyard or is it going to be a Kings Ransom"
What do you think?
Don-Wi
08-30-2005 20:18:52
 Re: Oh mr. Schwiebert - found the problem in reply to jeg, 08-30-2005 18:51:00
That shaft runs the hydraulic pump as well, so you're gonna need it. There should be plenty of 1800's in bone yards so the price should be some what reasonable. I don't have the information for Wisconsin tractor parts with me, but they are a part of All States Ag Parts, I think the website is www.asapagparts.com. They should be able to help you.
Donovan from Wisconsin
