Rear oil leak 1365
Marc Smothers
08-27-2005 17:24:13
Under my 1365 in the rear there are cotter type pins sticking down out of the casting and there is oil dripping out of the right one. I assume that maybe a seal is leaking from the brakes. DOes anyone know if that is the probkem, are if it is common problem?? THank you, Marc
marty g.
08-31-2005 05:05:10
 Re: Rear oil leak 1365 in reply to Marc Smothers, 08-27-2005 17:24:13
Hi Marc!
It's not a common problem. But for a tractor that age, you have to expect a few worn seals. Check the oil level on the outboard planetary, if its dropping, you will have an idea where the oil is from. Is it a big leak?
Marc Smothers
09-01-2005 17:20:45
 Re: Rear oil leak 1365 in reply to marty g., 08-31-2005 05:05:10
It leaves a puddle over night about 4" in size.. I can tell it is rear end oil not final drive oil. I just hoped someone had some idea before her apart this winter. I certainly understand the age issue as I don't many tractors newer.. They all run darn good though, and that little girl puts out close to (75) hp. last time on the dyno.. Thanks, Marc
