550 fuel strainer
Mark Trachy
08-27-2005 13:13:47
I removed the glass bowl on my tractor to clean the accumulation of dirt etc. from the bottom of the bowl. Now I can't seem to get the strainer to stop leaking when I re-assemble it. Perhaps I need new gaskets. (There were 2 cork ones on it) Is there a trick to getting it back together? The gaskets are less than 1 year old. A tractor repair shop did this last in October of 2004. Can new gaskets be purchased, or do I have to make my own? How tight do you tighten the nut on the bottom of the glass bowl?
Thanks.
Darryl Nealis
08-30-2005 13:02:41
 Re: 550 fuel strainer in reply to Mark Trachy, 08-27-2005 13:13:47
You can get gaskets for settling bulb. Sounds like who ever changed it last had a problem if there were two gaskets on it. I hand tighten mine on my 550 and then use a pliers to tighten it a little more if it leaks until it stops leaking.
