2255 puller
v8 ollie
08-24-2005 07:57:29
Is it possible to get my 2255 down to 10500# using cast centers this is a out of the field class any ideas would be appreciated thanks
newter haven
08-25-2005 19:48:14
 Re: 2255 puller in reply to v8 ollie, 08-24-2005 07:57:29
Lose the front tub maybe design a tube front to hold your motor must be stout enough to take twisting from the motor.
OliverGuy
08-25-2005 18:14:29
 Post some 2255 pics in reply to v8 ollie, 08-24-2005 07:57:29
Would love to see your 2255 pullers. That"s the good kind of big green stuff.
Lee Dixon
11-26-2006 11:40:50
 Re: Post some 2255 pics in reply to OliverGuy, 08-25-2005 18:14:29
Hello,
I was looking at your page and was wondering how I could put some pictures of my 2255 oliver on there?
Well if you could let me know just email me back or give me a call at 302-242-9650.
Thank you for your time
Lee Dixon DE
WFE
08-24-2005 20:04:18
I'd be happy to slim it down to 12,500 lbs. I don't think 12,500 lbs is even possible without going to a pressed steel center. I have seen some pictures of 2255s with a pressed steel center (between the planetary housing and the rim). Was this offered by Oliver for non row-crop applications possibly, as there doesn't appear to be any provision to adjust wheel spacing? For our farm stock classes, in order to use pressed steel to reduce weight, it had to be a factory option on that tractor.
2255 puller
08-24-2005 18:52:15
Probably not. Use wheels off a 1070 case. They are a pressed steel 10 bolt rim.
davects
08-29-2005 08:37:01
 Re: 2255 puller in reply to 2255 puller, 08-24-2005 18:52:15
I have mine down to 10,500. I made a set of rear rims and got rid of the cast centers. I installed a narrow front from a 1855. The cast nose is next to go. I hope to lose another 300 or so lbs. there.
