oil for pto unit
Jacket
08-20-2005 12:37:52
What oil should I use in the PTO unit of an 1850?
steven robertson
08-22-2005 07:58:53
 Re: oil for pto unit in reply to Jacket, 08-20-2005 12:37:52
90 WEIGHT
J. Schwiebert
08-20-2005 17:53:17
The PTO Final drive and transmission are all lubricated by a common fluid contained in the main case. If your asking something else I am sorry I did not understand the question. 80-90 Gear oil will work fine. There are two check plugs in the back near the PTO. Make sure the level is up to the top plug when the tractor is parked on a level surface. If you need to use the PTO and the tractor is parked on a slop with the front end down make sure the oil touches the bottom check plug before running it. Questions?
