OC-46 Final Drive.
oliver-newbie
08-19-2005 12:43:09
I have an OC-46 whose right final drive leaks oil almost as fast as it goes in :-(
However in the barn right next to the tractor is a box of parts from zimmerman including various gaskets & a trunion nut.
I have the shop manual and there is a whole rebuild procedure that looks doable but my question is can I just replace the seals without removing the final drives and doing a full rebuild.
I know I have to drop the track, remove the sprocket, remove the trunion cover but then are all the seals replacable.
Thanks in advance. Never worked on a crawler
JD in da UP
08-22-2005 04:26:26
 Re: OC-46 Final Drive. in reply to oliver-newbie, 08-19-2005 12:43:09
I've never worked on an oliver final drive, but if your seal is that bad, there is no doubt in my mind that you will have worn bearing trouble. Plan on going farther than just a new seal.
