Oliver Combine
RDD
08-14-2005 19:55:43
What newer Oliver model combine replaced the 545? and wasn't the 545 the same as a 4296 MM?
90%ret'd
08-15-2005 04:58:32
 Re: Oliver Combine in reply to RDD, 08-14-2005 19:55:43
Yes, the 545 was a 42 in. machine, same as the MM4296.
B A Star
08-14-2005 21:20:06
-> 545 -> 5555 -> 7800 -> 8800 -> 8900 -> 8920
RDD
08-15-2005 10:15:16
 Re: Oliver Combine in reply to B A Star, 08-14-2005 21:20:06
Will a cornhead off a 545 work on a 7600 Oliver model.
oliverfan
08-15-2005 17:50:24
 Re: Oliver Combine in reply to RDD, 08-15-2005 10:15:16
The 545 combine used the 500 series of corn head, and the 7600 used the 700 series of corn head.
The 500 series of corn heads had the feeder housing attached to it, and it would hook up just in front of the cylinder. Later they had a rube-goldburg hook up that they tried to pass as a quick hook up. But it was mostly a joke.
The 700 series were of the quick attach style with the feeder housing staying on the combine and the heads attaching on the outer end.
I do not think you could make a 500 series fit on a machine made for a 700 series.
With a 535 combine and a 7300 feeder housing you could, but you are asking about the 545 and 7600, and I think the answer is no.
Josh H
08-15-2005 08:17:48
I have a 7300 combine. What models came before/after it?
Josh
J. Schwiebert
08-15-2005 09:31:01
 Re: Oliver Combine in reply to Josh H, 08-15-2005 08:17:48
The 430 Combine, then the 535 and then the 7300
