removing the pulley gearbox
tim coltman
08-14-2005 11:03:53
hi i have more questions about the 88. i have to remove the pulley gearbox to get the shifter rails out how does it come off. i found bolts all the way around the bottom but from what i can see the input shaft for the tranny goes through it. what do i have to do to take it of. i do have the IT service manual but i dont see where it says how to remove geabox. thanks tim
J. Schwiebert
08-14-2005 11:23:00
 Re: removing the pulley gearbox in reply to tim coltman, 08-14-2005 11:03:53
Have you taken the hook & fuel tank off? There are 7 bolt and 2 dowel pins that hold that in position. You also need to remove PTO shaft and the coupler coupling the clutch & input shafts together. Six of the bolts are 3/8 inch the other one is half inch if I remember correctly? How is the clutch? You go through the same procedue to put a clutch in. Questions. Oh by the way set a five gallon pail under that opening. There is some oil in the gearbox and it does run out when you tip it up to remove it.
tim coltman
08-14-2005 11:49:51
 Re: removing the pulley gearbox in reply to J. Schwiebert, 08-14-2005 11:23:00
i am going to replace the clucth while i am at it it was getting bad but would still probably last awhile but knowing my luck i would put her back together and the clucth wuold go out a week later. thanks for tthe help. tim
