Super 77 timing
Doug Allen
08-13-2005 19:44:52
Can anyone tell me what is the correct procedure to time a Super 77 gas with a 6 volt system? Also, when did Oliver switch from a 6 volt system to a 12 volt system in gas. Thanks
J. Schwiebert
08-14-2005 09:51:06
 Re: Super 77 timing in reply to Doug Allen, 08-13-2005 19:44:52
I will do this in reverse order. Oliver gas tractors went to a 12 volt system for the 1957 models. On timing. The engine is timed at rated speed instead of idle speed like many engines. There is an IGN mark on the flywheel that you line up with the pointer in the window. You may need to clean the flywheel which you can do very easily by removing the starter, turn the engine over with a socket and when the mark shows up clean it and spray a little white paint on it. This will make the job alot easier. Questions?
