880 Clutch
Steve Merritt
08-13-2005 14:09:55
My clutch shaft only goes into the pilot bearing about .30", which is slightly only half way. The bearing is .55". I think is should go in at least another 1/8". The clutch shaft is the right length (it"s new). Is this normal? I was thinking about making shims to put between the flywheel and the pto hub which houses the pilot bearing. Any ideas? Thanks.
