1650 rear end
j meyer
08-13-2005 13:25:44
I am just about to buy a 1650 here, and the current owner had both drain plugs fall into the rear end thru the fill hole by the shifter. I guess I havent been in one for a few years, but it seems to me that theres a small compartment and then the big back one(for the rear end). Am I correct? I did fish around in there this morning and found one, but now to find the other. Gosh I would be nice to find the other without pulling off the hydraulics! Can anyone confirm that being a small compartment in front?? or any thoughts or places to look for the other. I am guessing she is sitting on top of a gear yet.....hopefully its not towards the back!
David M
08-13-2005 21:49:25
 Re: 1650 rear end in reply to j meyer, 08-13-2005 13:25:44
Yes there is a small compartment in the front. Did you try removing the gear shift? That's about the easiest access to the front of the case. Good luck.
Loren
08-14-2005 10:18:42
 ???? in reply to David M, 08-13-2005 21:49:25
I'm curious about this as I decided quite a while back my first pick would be a 1650 if money wasn't a problem. How are the plugs/hole made so that a plug can fall in? Tapered pipe thread and repeated checking without replacing the plugs when they get too loose?
j meyer
08-14-2005 14:24:47
 Re: ???? in reply to Loren, 08-14-2005 10:18:42
To David- thanks for confirming my thoughts
To Lorin- What happend on this tractor is that this guy bought this tractor about 5 years ago and brought it home and drained the rear end oil and opened the fill cap by the shifter. He for whatever reason set his drain plugs by the fill hole and bumped them and they fell into the rear end. Today I got the other one out and paid for it, so I am the owner of this 1650. You wont have any issues with your drain plugs unless you pull some sort of oops like this.
