cockshut 570 super crankseal question
bison
08-12-2005 20:33:26
I have a leaking rear crankshaft seal on a 570 super with a straight six diesel.
my question is , do i have to split the tractor to get to this seal or do i have to take the oilpan off.
i don"t have a shop manual for this tractor.
thanks simon
recovery specialties
08-23-2005 13:57:36
 Re: cockshut 570 super crankseal question in reply to bison, 08-12-2005 20:33:26
I have a shop manual for the 570 tractor if you want to purchase one to help you with your overhaul. Thanks Keith 519-842-6264
Dave Morlock
08-13-2005 18:39:14
Pull the engine, not very hard to do. Remove clutch and fly wheel and seal is right there, you do not remove oil pan for this. I just replaced one on a tractor with the Hercules engine, got seal from Phil. One thing to look for make sure you leak is not from rear arch of the oil pan>>> That can be changed with engine in the tractor, you can get that from Phil also. I replaced both, but I think my pan gasket arch leaked worse than rear seal.
P Heisey-Harleysville,PA
08-13-2005 02:47:08
Bison Simon,
Either split the tractor or remove the engine, whichever is easier for you. I have the parts you need.
Phil Heisey 215-256-8651 FAX 215-256-1203
