Found and oliver power unit what engine??
old
08-07-2005 21:22:48
Looking at and oliver power unit. Its a 4 cylinder and sort of looks like it would fit right in to a tractor what might that engine be. Also its locked up from sitting is it worth $250. The sheet metal looks good and unit is complete whith a clutch assembly and maybe a small tranny.
Thanks
oliver fan
08-08-2005 09:33:11
 Re: Found and oliver power unit what engine?? in reply to old, 08-07-2005 21:22:48
OLD
Oliver made a lot of different power units, and most cases they were the same as the tractor engines.
You said it is a 4 cylinder so here is a list of most of the statonary power units I know of.
28 same as a 18-27 & 18-28 tractor engine.
44 same as a 28-44 and 90 tractor engine.
35 same as a 80 tractor engine.
80 same as above.
50 same as 99 (4) engine.
99 same as above.
166 same as a 66 tractor engine.
There was a super 166 engine that was like a super 66 tractor engine, and I think the late super 166 engines were like the 660 tractor engines. I know the power-pak units (engine, transmission) were still being built into the mid to late 60's.
No need to list the 6 cylinder engines.
This list is not complete I am sure, but it will give you an idea.
