two drain plugs super 77 transmission and rear end
nikkino
08-07-2005 09:18:43
two drain plugs on oliver super 77 for trans. and rear end,where is filler located for rear end thanks ken hartland maine
jjld
08-07-2005 15:51:49
 Re: two drain plugs super 77 transmission and rear in reply to nikkino, 08-07-2005 09:18:43
Trans and final drive fill from the same opening. It's a 2 level splash system. A casting baffle creates the two levels.
ejr-IA.
08-07-2005 09:43:09
Top deck right front of gear shift lever under the hydraulic filter should be a aluminum plug thats the fill hole.
