Hercules 339?
James Tierney
08-03-2005 20:01:42
Does anyone know, does a Hercules 3400 or D339 have 4 intake ports and 6 exhaust? Block number appears to be 40 300 7
Thanks
P Heisey-Harleysville,PA
08-04-2005 03:43:38
 Re: Hercules 339? in reply to James Tierney, 08-03-2005 20:01:42
James,
YES, you are right on the port counts for a Hercules D339H series engine that is used in the COCKSHUTT 570 Super. The Hercules DD298, used in the COCKSHUTT 570D , also uses the same port configuation. I checked the block casting numbers on one of my 570S tractors. The numbers behind the generator are E293 400D.
I hope this helps.
James Tierney
08-04-2005 05:36:17
 Re: Hercules 339? in reply to P Heisey-Harleysville,PA, 08-04-2005 03:43:38
Thanks for the help.
