Cockshutt tractor { ring gear for fly wheel}
Ross Toole
08-03-2005 06:50:32
Hi I have tractor that needs a new ring gear for the fly wheel this one is to far gone .How do i ever fine one.Cockshutt tractor 540 model f162 /gfec 1698/ engine #259081.I realy want to get this old tractor going it has a front end loder ans we have lots of snow !!!thanking you all in advance Ross Toole
J. Schwiebert
08-03-2005 06:54:18
 Re: Cockshutt tractor { ring gear for fly wheel} in reply to Ross Toole, 08-03-2005 06:50:32
Should not be a problem. Do you have the flywheel off? Two things to do. Count the number of teeth on the ring gear. It will or should have a number stamped on the ring gear. I need those two items of information. I know a Continental dealer that probably has one in stock. Where are you located? Questions?
Ross Toole
08-03-2005 07:04:55
 Re: Cockshutt tractor { ring gear for fly wheel} in reply to J. Schwiebert, 08-03-2005 06:54:18
We live in Truro Nova scotia canada
P. Heisey-Harleysville,PA
08-03-2005 15:28:53
 Re: Cockshutt tractor { ring gear for fly wheel} in reply to Ross Toole, 08-03-2005 07:04:55
Ross,
I have NEW starting ring gears on stock for your Cockshutt 540 Tractor. Please let me know the tractor serial number so I can quote and supply the exact right one.
Phil Heisey 215-256-8651 FAX 215-256-1203
