Oliver 60
Anderson
07-29-2005 15:10:19
I found an Oliver 60 and the engine is bad. Is the engine found only in the 60 model or is it the same as another tractor? Also, where can I find another engine for a 60?
havvey
07-30-2005 14:03:43
 Re: Oliver 60 in reply to Anderson, 07-29-2005 15:10:19
again check ebay i have seen several blocks on there. and advertise on the tractor sights. not an uncommon item you may find a complete engine in need of rebuild. A block could be shipped but a little exspencive. those 60's were a fun little tractor. email me as i have a collector friend that may have a good block!
J. Schwiebert
07-29-2005 16:28:15
What is bad on your engine?
Anderson
07-29-2005 20:15:00
 Re: Oliver 60 in reply to J. Schwiebert, 07-29-2005 16:28:15
The bad thing on the engine is the block. It is stuck and at one time had water in it and broke and someone welded it up. So maybe could get by with just finding another block.
HAVVEY
07-29-2005 15:22:40
FAR AS I KNOW ONLY IN A 60 A BIT EXSPENCIVE TO REBUILD BUT SEEMS LIKE A LOT OF PARTS SHOW UP ON EBAY AND OTHER SITES. I BELIEVE YOU WOULS HAVE A HARD JOB FINDING A GOOD RUNNING ENGINE IN A PARTS/BAD TRACTOR. HOPE YOU GET IT CHEAP. LIKE LESS < $300
