HELP, bypass valve, Super 55
Super 55
07-16-2005 15:09:24
I have an early Super 55, serial # 16-011-518.
I have rebuilt the hydraulic pump and I am replacing all of the "O" rings and seals. I am sort of stuck on one part of the hydraulics. I have the manual and the parts book for Super 55s. I am making sure everything is clean and in working order before I put the transmission cover back on the tractor. In the manual it says to remove the oil pressure bypass spring and valve plunger for inspection. (manual figure showing this is 10-M if you happen to have the manual) but I can not see anyhwere in the casting this could be. Did the early Super 55s not have this feature? I can't even find it in the parts book. Anybody have some information? I am relunctant to put it back together and reinstall the transmission cover before clearing this up. For me time is of the essance. I have this window of opportunity called "summer holidays" that can not be extended.
