A couple of thoughts: 1) The timing may be off something other than 180 degrees, if you didn't get the oil pump phased correctly to the camshaft, not much you can do but move the wires around the cap to match the engine rotation. To do this you will have to determine TDC of #1, and work from there. To find TDC pull all of the plugs, and put your thumb over #1, or if you have a small plastic cap that will fit into the hole, it will launch when you get #1 on TDC. To make sure you have it at TDC take a small dowell rod reach into the plug hole and slowly rotate the engine back and forth. This will tell you where # 1 is and install the plug wires from there, in the normal firing order. 2) The valve timing could be off, this is a little harder to determine, with the valve cover off, find #1 TDC as above, then slowly rotate the engine (as if it were running, I look at the fan to make sure I am turning it the correct way) and watch the valve movement, it should be close to 1/2 rotation valves closed, 1/2 rotation exhaust valve open, 1/2 rotation intake valve open, 1/2 rotation valves closed (at the end of this stroke the plug should fire). If the valve timing is off, you will have to remove the front of the engine and reset the timing gears. By the way the last engine I rebuilt the timing was 180 off, and it took awhile to figure it out and get it running, and even after correcting the timing, it still took several minutes to get it to run. Good Luck Rich
