Pulling the lift of a 1949 RC 77 HELP!!
Jordan Flagstad
07-15-2005 20:56:58
Hey guys, Looking for some input from someone who has done this before. In pulling the belly lift off of my 1949 RC 77, do I need to pull the dash, hood and fuel tank? I need to get into the trans to do some work, and can't seem to get this lift off.
Thanks,
Jordan
East Bethel, MN
Jordan Flagstad
07-17-2005 20:13:14
 Re: Pulling the lift of a 1949 RC 77 HELP!! in reply to Jordan Flagstad, 07-15-2005 20:56:58
Thanks guys for all of the advice, I got the old girl fixed and she is back shift great again.
Thanks,
JSF
evielboweviel
07-17-2005 10:12:11
for the mechincal lift you do not need to pull the pto.
ONLY pull the pto when equipped with hydraulics.
no need to pull the gas tank, dash etc.
Good luck
Ron
tom upton
07-17-2005 19:32:24
 Re: Pulling the lift of a 1949 RC 77 HELP!! in reply to evielboweviel, 07-17-2005 10:12:11
Ron - sorry. you are right about not having to pull pto for removal of mech. lift. I had hyd. unit on my absent mind.
tom upton
07-17-2005 07:57:44
No you dont have to pull dash to get lift off. Bolts that are on front of lift are a bit tuff to get at but a universal and a extention should do the job. There are also flanged dowel pins in oppisite corners of lift that you should pry up with a heel bar or something prior to trying to lift off. I usualy unbolt the seat brkts first and remove the whole seat unit so you can work at it and lift off a lot easier. Watch you dont lose the springs that center the shifter when you are pulling it on and off. From other posts you allready know you have to pull the pto shaft out.
Tramway Guy
07-16-2005 19:14:54
Are you talking about the mechanical lift or the hydraulic lift? It makes some difference.
Jordan Flagstad
07-17-2005 07:21:15
 Re: Pulling the lift of a 1949 RC 77 HELP!! in reply to Tramway Guy, 07-16-2005 19:14:54
I am speaking of the manual lift, that the shifter goes through. I do have a shop manual, but it doesn't show what I am looking for.
old
07-16-2005 08:16:39
First thing you need to do is get a repair manual!!! Also to pull it you need to remove the PTO assembly since it gets its power off the pto shaft. Its not all that hard to do just a pain.
Jordan Flagstad
07-17-2005 07:25:18
 Re: Pulling the lift of a 1949 RC 77 HELP!! in reply to old, 07-16-2005 08:16:39
I have a repair manual!!! It does not show what I am asking here. I am simply asking if anyone has ever done this and in what order does this stuff come off. Like do I need to pull the dash? The tank? the hood?
I need to get in there to free up the shifter linkage as I can't seem to get it through the shifter hole.
Jordan
MN
old
07-17-2005 10:40:17
 Re: Pulling the lift of a 1949 RC 77 HELP!! in reply to Jordan Flagstad, 07-17-2005 07:25:18
All you need to pull is the PTO shaft and then you can pull the lift. You don't need to pull the dash etc.
Lee W
07-16-2005 06:42:55
Did you remove the live power shaft, it goes through the hyd pump and in to the flywheel?
