One more filter question? - 1850
mud
07-12-2005 10:25:50
How about a cross reference for the oil filter & hydra (over-under) filter?
Sure appreciate it. Tractor has sat for 2 years and this coming weekend it gets put to work after fluid changes.
Thank you in advance, it's been a long time coming on this project.
mlm
07-14-2005 08:17:35
 Re: One more filter question? - 1850 in reply to mud, 07-12-2005 10:25:50
At one time, they would cross over to the old standard Ford/Dodge engine oil filter(ph43-ph1 ?). Maybe this is not so anymore, once they upgraded the filter in 88.
Dean Barker
07-12-2005 21:49:07
Starting in 1987 or 1988, a much better filter was made available for the over/under and hydra-power from White and now from AGCO. It is 30-3475425. There is one problem, however. AGCO wants $44.00 each for these. I've been reserching different filter manufacturers for an equivalent filter, but so far have not found one.
I will post if I do find one.
mud
07-13-2005 06:56:31
 Re: One more filter question? - 1850 in reply to Dean Barker, 07-12-2005 21:49:07
OUCH! Holy Moses! AGCO likes their stuff dont they?
Reminds me of what they want for the tach cable- $101.00 -
Sam M
07-12-2005 10:50:49
I use a NAPA filter , I think it is number 1307 .
mud - same filter for bot
07-12-2005 13:31:36
 Re: One more filter question? - 1850 in reply to Sam M , 07-12-2005 10:50:49
Do I use the same filter for both the final drives and the over-under? I looked through the archives and it appears so but want to check.
mud
Don-Wi
07-12-2005 15:14:55
 Re: One more filter question? - 1850 in reply to mud - same filter for bot, 07-12-2005 13:31:36
yep, same filter for the final drive and over/under or hydra power in the earlier ones. I guess at one time one was taller than the other but it was discovered that it didn't need to be.
Donovan from Wisconsin
mud
07-12-2005 15:21:05
 Re: One more filter question? - 1850 in reply to Don-Wi, 07-12-2005 15:14:55
Thanks Donovan- I might just get this thing where I can use it this weekend. Same filter? That makes thing simpler. I need that. LOL!
mud
Don-Wi
07-12-2005 20:00:41
 Re: One more filter question? - 1850 in reply to mud, 07-12-2005 15:21:05
You and me both!! I ordered a new steering wheel for my 1600 and got it today. It has a newer hydra-moter in it like from a 1655 or 2-70, and the new steering wheel, said to fit 1650's-1855's, etc...., doesn't fit mine. The bore is too small. I have to give Korve's a call tomorrow and ask a little bit. Really want to get one through them as a new one from AGCO is atleast $40 more and it doesn't look as nice in my opinion. may have top though. I hope to fire it up on Saturday if I can get my radiator back from being re-cored in time. Donovan from Wisconsin
