OC-3 Engine Removal
Joe Truchard
07-10-2005 18:22:06
I am trying to remove an engine from an OC-3 frame bolted to the clutch housing. I removed the two bolts into the clutch housing that seam to be bolted onto the frame. I also jacked up the front end to releave the pressure including losening the very long bolt that goes through the frame. The engine will not budge. Are there more than the two bolts on each side holding the engine. Thanks for any advice.
hector gemme
07-11-2005 01:40:16
 Re: OC-3 Engine Removal in reply to Joe Truchard, 07-10-2005 18:22:06
HI I take off mine for parts last week and I TAKE OFF EACH SIDE 4 BOLTS.
RAB
07-10-2005 23:16:18
Yep, more than 2 bolts each side.
Regards, RAB
