Over/Under shifting on its own
keystone
07-08-2005 04:55:38
I have an Over/Under Hydraul shift and under a heavy pull it shift back to direct be itself. Any ideas on what is causing this?
J. Schwiebert
07-09-2005 16:22:38
 Re: Over/Under shifting on its own in reply to keystone, 07-08-2005 04:55:38
Have you check the clutch circuit pressures, both direct and overdrive?
bradk
07-08-2005 06:33:47
I'd service unit new fluid & Agco filter,when removing drain plug,look to see how much debris is stuck to magnet in plug.This will give you an indication of the condition of unit.~brad
L Klingler
07-08-2005 06:24:38
Is it low in oil?
keystone
07-08-2005 06:52:22
 Re: Over/Under shifting on its own in reply to L Klingler, 07-08-2005 06:24:38
No. It is on the full mark. It was purchased as a sued unit and has been fine until it started the downshift problem.
